98 s10 ext cab v2203 700r4 4x4 sas
Old Apr 4, 2016 | 10:04 PM
spencxr80's Avatar
Default 98 s10 ext cab v2203 700r4 4x4 sas
I have been collecting parts for a while and working on the bell housing adapter I am about ready to start on the truck itself I will try and get some pictures of the bell housing and flexplate adapter up soon
Old Apr 5, 2016 | 06:53 AM
yellow68gto's Avatar
Looking good. Good to see another swap come up
Old Apr 5, 2016 | 07:51 AM
dieselxj's Avatar
yeah a new Kubota conversion. I am a little lost. is that a Kubota flywheel? with the center section filled? with the crank adapter? and then then the crank adapter on the aft side of the flywheel to take the GM flexplate?
looks good though keep the updates coming
Old Apr 5, 2016 | 11:07 AM
spencxr80's Avatar
I should have taken pictures when it was apart the adapter is actually a piece of Chevy crankshaft cut off and cut with a shoulder and pressed into the Kubota flywheel then I drilled it
Old Apr 5, 2016 | 02:27 PM
spencxr80's Avatar
Here is a picture of the whole thing put together just waiting on a new flexplate
Old Apr 5, 2016 | 08:28 PM
usedkubotaman's Avatar
Cool! It'll be interesting to see how the 4x4 and 700r4 work out. Should be fine.
Old Apr 5, 2016 | 08:53 PM
spencxr80's Avatar
Here is the truck and the bumper I'm building for it
Old Apr 6, 2016 | 10:41 AM
FTE's Avatar
FTE
Looking good! I did a similar setup with the flywheel adapter bolted to the Kubota flywheel in a Cherokee with an AW4 auto. It worked great. Don't forget to bump the timing up and stiffer gov spring while you have it out. It a lot easier now, removing all the shims from under the ip gives it @ 11deg.
Old Apr 6, 2016 | 10:49 AM
spencxr80's Avatar
Before I found out about the shims I have already pulled the front case off and advanced the pump cam one tooth witch will give me about 6deg I wish I knew about the shims it would have been way easier
Old Apr 10, 2016 | 03:34 PM
spencxr80's Avatar
The flexplate came in to mail yesterday so after I drilled the extra three hole I bolted it all together
