Passenger Vehicles General Discussion General Diesel Discussion of all Passenger Vehicles with Diesel Engines
Does a dump valve work on a diesel engine?
Old May 27, 2008 | 03:57 AM
lancerevodiesel's Avatar
Default Does a dump valve work on a diesel engine?
Thanks for your replies.
Old May 27, 2008 | 11:27 AM
Whit's Avatar
Site Mascot
explain dump valve to me???
a run away diesel can be choked off ONLY by removing the air
air cut off valve works great and is manditory for pullers
Old May 27, 2008 | 12:25 PM
a dump valve or blow off valve like on a petrol engine.
Old Feb 9, 2009 | 03:29 PM
Deezel Stink3r's Avatar
A gas engine has a throttle body and a throttle plate.During shifting the gears the throttle plate closes and restricts the airflow. During that moment the BOV opens to get rid off the excess pressure, which could bend the throttle plate.
A diesel has no need for a throttle body or plate- so there is no reason for a BOV.
There is only a wastegate- to get rid of the excess pressure which would damage the turbo
Old Feb 9, 2009 | 04:51 PM
kazairl's Avatar
Actually A blow off vlave can be of use on a diesel. It it used to prevent barking the turbo when the throttle is suddenly lifted. However on a diesel it uses drive pressure to keep it closed instead of vaccum to pull it open.
And actually your new emissions friendly diesels have throttle plates. FYI.
Old Feb 9, 2009 | 09:21 PM
ChinookFE's Avatar
Would a regular BOV work or would you need a different style for a diesel. Where would you mount it? I just installed an external BOV on my buddies Neon SRT-4, we put it on the up-pipe between the intercooler and the throttle body, where would you put it on a diesel? Same place?
Old Feb 9, 2009 | 09:48 PM
94cummins12v's Avatar
they are specific for diesels,
Old Feb 10, 2009 | 12:25 PM
kazairl's Avatar
You'll need a piston style BOV. The Diagphram types won't stand up to the heat from the DP line. You can mount it anywhere you feel like. It doesn't make much of a difference. As long as it is between the Turbo outlet and the head you'll be good.
You'll need to drill a hold in your exhaust manifold so you can run your Drive Pressure line to the BOV.
Old Feb 11, 2009 | 02:30 AM
jnicewan's Avatar
some factory diesel engines use these and it is a good idea also. it will eleminate turbo bark, decrease turbo lag and prolong turbo life. most installs are between turbo outlet and cac
Old Feb 11, 2009 | 04:35 PM
kazairl's Avatar
Originally Posted by jnicewan
decrease turbo lag
You'll have to explain to me how it does that^
