AC/heater noise
Old Jan 11, 2016 | 08:17 PM
Mr.bacon's Avatar
Default AC/heater noise
So my 05 3500 is making a noise when the Ac and heater are on high. Not from the engine bay but within the cab. Is it the blower fan or something (not sure how it's built to be honest). Anyone have this issue? Also should note it doesn't have any force behind the air. Basically a lot of noise without the blowing power. Takes a while to defrost the Windows, very annoying. Didn't notice it when we got the rig since it wasn't that cold.
Thanks all
Old Jan 11, 2016 | 09:00 PM
CumminsCoalRoller24/7's Avatar
Thanks all
There's a blower motor/fan toward the front kick panel below glove box- you can take cover off with a torx head, there should be 4 screws. My father in laws was making a bunch of noise and somehow a screw fell in there- maybe somewhere to start!
Old Jan 11, 2016 | 11:03 PM
dangerous1965's Avatar
yup either something in there or the bearing is going out!
Old Jan 11, 2016 | 11:39 PM
Mr.bacon's Avatar
Thank you gentleman! I honestly had no idea how easy it was to Accsess the motor and fan was. Also didn't quite realize how easy it is for things to get in there.
Will be working under the dash and seeing what's in there.
Old Jan 12, 2016 | 08:24 PM
texasgreg's Avatar
The lack of air may be due to a door failure. This has videos and replacement doors;
Dodge Ram '02-'08 - '02 - '08 - Ram - Dodge
On my '06 I had to pull the entire dash. '05 is supposed to be easier if you have to change doors.
Old Jan 14, 2016 | 05:42 PM
Mr.bacon's Avatar
Well... There was two problems. The noise was from a clogged blower fan, and there was a plastic piece, like a hinge.
But then while inspecting the inside of the fan housing. I noticed the door above the fan is broken. So.. Hopefully it's not a pain to fix or can be done cheap. Luckily I have a shop near by that we've brought a lot of business too. So when they change the oil maybe I can get them to do that as well for a good price. Just don't have the time to do it myself right now.
Do you know what it might cost to replace that damn door?
Old Jan 14, 2016 | 08:57 PM
I have never done the fan door you're mentioning but I think this is what you're looking for, Sorry it's not from another bomber!
http://dodgeforum.com/forum/3rd-gen-ram-tech/327284-just-replaced-the-infamous-recirculation-door-in-30-minutes.html
Old Jan 16, 2016 | 12:56 AM
Mr.bacon's Avatar
Just replaced the infamous Recirculation Door in 30 minutes :-) - DodgeForum.com
That helps a lot! But, I did find it because of another bomber! Just as good in my book haha.
