295/70R18 Nitto Trail Grappler actual size
Old Dec 26, 2015 | 03:07 PM
jbz28's Avatar
Default 295/70R18 Nitto Trail Grappler actual size
Hey, I'm considering the 295/70R18 Trail Grappler and was hoping someone would help me out by measuring the actual height and width. I know the Nitto site has the measurements but their's nearly an inch difference in height to my actual measurements for my 285/65R18. I'd like to know if I can squeeze them in with out rubbing or minimal rub. I'm running a -12 offset with a level kit so it makes things a bit tricky.
Thanks in advance.
Old Feb 8, 2016 | 07:11 AM
vicp21's Avatar
This site can give you an idea of what the 285 vs 295 should be.
https://tiresize.com/height-chart/
Old Feb 8, 2016 | 04:57 PM
jbz28's Avatar
Thanks for the response. I actually use that site often. The numbers that tire manufacturers post don't seem to be accurate so I was hoping to get some actual measurements. An example I can give is a set of mickey thompson baja ATZ listed as 35x13.5.r20 actually measures 34x13.50. I just wish they would list the actual size of the tire. It would make things much easier.
Old Feb 9, 2016 | 05:01 AM
vicp21's Avatar
Oh, yeah that's more of a "your results may vary" thing ha
