1987 6.2 - Glow plugs won't light
Old Dec 14, 2015 | 11:05 PM
Daximus11's Avatar
Default 1987 6.2 - Glow plugs won't light
Have a 1987 2500 with 6.2. Glow plugs will not light, therefore engine will not fire. Have converted to manual switch, worked for a couple days then nothing. Check all electrical connections to solenoid, harness, controller, battery. Was used in warmer weather as daily driver, now in colder climate. Old truck that just needs to be used for hauling. Any suggestions on what to check/do next?
Old Dec 15, 2015 | 04:24 PM
j johnson's Avatar
this might sound crazy but have you checked the solenoid out for proper working order..with it not working the glow plugs will not come on...glow plugs all might be bad...should read no more than 1 ohm each...hope this helps...scott
Old Dec 15, 2015 | 08:38 PM
Daximus11's Avatar
Thanks jjohnson. Will be taking readings from both solenoid and glow plugs. Thank you.
Old Dec 20, 2015 | 10:27 PM
Chacalanay's Avatar
Just joined for some answers
Old Dec 20, 2015 | 10:29 PM
Chacalanay's Avatar
Probably easy for you all 97 cummins auto want to make it to the higher hp that comes inthe standard trans
Old Dec 20, 2015 | 11:08 PM
Tanman_2006's Avatar
I bet you fried the glow plugs with extended time. The OEM plugs bust at more than 5 sec unless really cold.
Old Dec 28, 2015 | 04:17 PM
Waxball88's Avatar
This I did not know, thanks!
