Rough idle need help!!!!!!!!!
Old Oct 18, 2015 | 06:56 PM
Brendancory1992's Avatar
Default Rough idle need help!!!!!!!!!
http://youtu.be/f9Lx9ZhvT9I
Happened while I was at a stop light. No signs of trouble just happened out of no where. No power when I hit the throttle. No idea what it could be. Anyone that could help me out?!!!
Old Oct 19, 2015 | 07:06 PM
FRIDAY88's Avatar
Is it hard to start?
Old Oct 19, 2015 | 07:29 PM
No the it starts up like normal but immediately goes to ruff idle and if I go to drive it, it has no power hardly and sounds sometimes like it wants to stall. But i assume that's just because the rpms are jumping all over the place
Old Oct 19, 2015 | 08:37 PM
FRIDAY88's Avatar
Any codes? What's been done to the truck
Old Oct 19, 2015 | 10:19 PM
The check engine like came on but I can't find anyone with a code reader plus an auto shop around me charges up to 100 dollars. I can't even drive the truck, has no power hardly. The only performance upgrade is a 6 set tuner chip.
Old Oct 19, 2015 | 11:27 PM
FRIDAY88's Avatar
I honestly would get a code reader before you go picking and throwing parts at it if it has a CEL it will most likely tell you the problem
Old Oct 20, 2015 | 10:14 AM
Yea that been my plan just working on finding one
Old Jul 19, 2016 | 06:52 PM
PacRat's Avatar
My 2004 was doing the same thing. I replaced the ipc and the plug for it. Helped for a couple days then went back to the same problem. Believe it or not I unplugged the Mass air flow and the ipc coated them with electrical silicone and plugged them back in. Problem solved cost $7.00
Old Jul 22, 2016 | 12:47 PM
Bigg Redd's Avatar
Take it to an Autozone or Oreilleys and you can have it scanned for free, and they'll give you a print-out with the code(s). Then, you can fix whatever needs fix'in.
