86 6.9
Old Sep 27, 2015 | 02:17 PM
bobaloo52's Avatar
Default 86 6.9
I recently changed the o rings and washers etc. in my fuel injectors because some of them were leaking. When I tried starting it, it started for a few seconds blew out alot of smoke and died. Before removing the injector pump, I made marks on the timing gears and made sure they lined up on re-assembly. It was dark when I put the pump back on and pinched the wires that go to the pump, between pump housing and top of the motor. I checked for continuity, and 12 volts on the double wire and it was good. This is an 86 ford f350 6.9, any suggestions would be greatly appreciated.
BOMB ON, bobaloo!
Blanton
Apr 15, 2015 06:29 PM
greasesheik
Apr 9, 2015 09:33 PM
tumble72
8
Nov 27, 2014 10:31 PM
Bigredpowerstroke
Nov 12, 2014 03:33 PM
tumble72
Nov 10, 2014 08:41 PM
