6-5 no fuel to injectors
Old Aug 28, 2015 | 03:14 PM
garyspruyt's Avatar
Default 6-5 no fuel to injectors
1997 gmc 6.5td no fuel to injectors, i replased pmd, changed ip, lp works good,bled system numerous times has fuel to ip, still no fuel to injectors, one thing i found today was im only getting .11volts between ground and green wire on pmd harness i read it should be 1.2 volts, why is the voltage low, ive cleaned and tightend all grounds that i can find, im stumped
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
JJ Diesel
Feb 25, 2015 02:52 PM
moneypitk5
Feb 12, 2015 11:01 AM
