01 Cummins Dead pedal lope idle
Old Aug 22, 2015 | 08:34 PM
Daylon's Avatar
Default 01 Cummins Dead pedal lope idle
I'm in need of some advice. My 01 24v Cummins 6spd manual died on me goin down the highway. After a minute of cranking it over it started but idled just under 300 rpms which causes a terrible loping idle. I also have a dead pedal, however while releasing the clutch in gear the rpms build up like theyr supposed to. Then when its completely disengaged right back to the rough idle and dying. Any help is greatly appriciated.
Old Aug 23, 2015 | 01:01 AM
Jet A Fuel's Avatar
Check your apps and also check for codes. Any mods on the truck?
Old Aug 23, 2015 | 10:50 AM
Daylon's Avatar
How do I check apps? All iv got on it is FASS lift pump and Edge prpgrammer .and codes are p1689 and 1693
Old Aug 23, 2015 | 11:01 AM
Daylon's Avatar
one code is from instrument cluster saying use scanner, and the others from the scanner saying no communication between ecm and VP.
scottxmorris
Jan 11, 2025 11:24 PM
burndiesel
10
Feb 7, 2023 01:15 AM
JoeyMiR
9
Feb 3, 2018 10:05 PM
Daylon
Aug 22, 2015 02:04 PM
aaronvadner
Mar 4, 2015 12:53 AM
