Not starting!!!!!
Old Aug 10, 2015 | 10:31 PM
Dur4max04's Avatar
Default Not starting!!!!!
Hoping someone can help me, I have a 03 5.9 cummins and it will not start, I've checked wires, tried a new switch commuter, and the actual ignition switch, as well as a brand new starter, and it still will not even turn over, I've tried putting it in neutral. Still nothing, does anyone have any idea what it may be?? Also check the neutral safety switch, any help will be truly helpful thanks is advance
Old Aug 11, 2015 | 09:26 AM
dangerous1965's Avatar
What is your battery voltage? Clean all your grounds and battery connections! As a far shot on the firewall drivers side there is a yellow connector that goes to the battery if that is disconnected will not crank. It's a push together wire YELLOW CONNECTOR. Did you try and jump the starter?
Old Aug 11, 2015 | 11:50 AM
Dur4max04's Avatar
Thanks for the reply, I've checked the wire running to the starter and it was nearly 13 volts I will check for the yellow wire in a few, I have jumped the starter and it does start.
Old Aug 11, 2015 | 12:10 PM
Jet A Fuel's Avatar
Might try the starter relay,
Here is a schematic for your truck starting system. hope this helps
starting-charging-starting-circuit-1-of-1 2003 chevy.pdf
dskewes14
Sep 14, 2015 09:19 AM
GasItOut
35
Jul 22, 2015 01:11 PM
gunman41mag
The Sportsmen's Lounge
Jul 1, 2015 10:21 AM
Squirt
Jun 19, 2015 12:40 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
