Smoke Screw
Old Jun 23, 2015 | 04:24 PM
Fred427's Avatar
Default Smoke Screw
when I bought my 91 non intercooled the smoke screw was cranked all the way Down. No longer has a lock nut. Is it beneficial or should I back it out some. Not sure if this would effect how the fuel pin and diaphragm works.
Old Jun 29, 2015 | 09:43 AM
u2slow's Avatar
Sounds like the PO didn't know there's other adjustments you can make
I would check how the fuel pin is indexed - its offset-ground so depending how you install it, utilizes a more/less aggressive profile. Use the most aggressive profile, back the smoke screw out some, read up on adjusting the fuel screw instead, and maybe advance the pump timing.
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
gagemotors
Jun 9, 2015 04:24 AM
ASarsano
Oct 15, 2014 05:33 AM
