Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
THINNER DIFFERENTIAL OIL
Old May 17, 2008 | 01:22 AM
scoggins's Avatar
Default THINNER DIFFERENTIAL OIL
HAS ANYONE TRIED TRACTOR HYDROLIC FLUID IN THE PLACE OF DIFFERENTIAL OIL
HAS OR AM I A FOOL FOR THINKING ABOUT IT?
THE IDEA BEHIND IT IS THAT IS IT MUCH MORE FLUID THAT GEAR OIL IT HAS PRETTY GOOD SHEAR AS WELL AS HEAT TOLERANCE AND LONGEVITY WITH 50#+ OF METAL FLOATING AROUND IN THE FRONT AND REAR IT MAKE SENCE TO LUBE THEM WITH IT IF IT WOULD NOT HURT ANYTHING
QUESTIONS COMMENTS????
Old May 17, 2008 | 06:51 AM
Heath's Avatar
Authorized Amsoil Dealer
The gear lubes are GL-5 rated for our trucks. They contain high levels of extreme pressure additives. The hydraulic oils that I looked at make no mention of any EP additives and are not rated of course because they aren't made for that appliaction. If not EP adds, then you would be set up to lose a diff very soon.
Old May 18, 2008 | 01:06 AM
scoggins's Avatar
HYDROLIC FLUID IS DOING THE SAME JOB ON A LARGER SCALE IN THE REAR END HOUSING OF ANY GIVE FARM TRACTOR NOT TO MENTION ALL OF THE "HEAVEY EQUIPMENT THAT IS USIING IT TOO AS A DIFF. FLUID
Old May 18, 2008 | 01:37 AM
2500HeavyDuty's Avatar
and the military uses engine oil as ATF so what?
and i wouldn't use hydraulic oil as diff lube either
Last edited by 2500HeavyDuty; May 18, 2008 at 01:37 AM. Reason: Automerged Doublepost
Old May 18, 2008 | 02:14 AM
Diesel-N-Dust's Avatar
First post summed it up, you need that heavy oil between the gears.
Old May 28, 2008 | 12:08 PM
dukeboy_318's Avatar
yep, especially in limit slip applications
Old May 29, 2008 | 09:51 PM
dieseljunkie's Avatar
Why would you want a lighter weight oil in your diff? Lighter oils are not going to offer the same protection as the heavier stuff. Just my opinion though.
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
cutthroatxxx
May 18, 2015 11:10 AM
coors_man_2005
Dec 15, 2014 10:23 AM
