pensacola preformace parts??
Old Jun 17, 2015 | 08:57 PM
Walker.B's Avatar
Default pensacola preformace parts??
i know that the injectors they sale suck but what about this?
https://pensacoladiesel.com/product-...e-billet-wheel
Old Jun 18, 2015 | 12:47 PM
duramaxtuner's Avatar
FormerVendor
I have never come across those injectors. We have tried several brands throughout the years here. But the best in the industry, IMO, is Exergy. That is why they are the only high pressure fuel injection parts we sell. If you need a quote, let me know.
Old Jun 18, 2015 | 08:48 PM
Walker.B's Avatar
im looking more for a budget turbo upgrade id like a lower rmp spool to help with towing and trailing throttle response my turbo charger could use a rebuild so ive been looking into billet wheels ect
Old Jun 22, 2015 | 10:48 AM
2004LB7's Avatar
if you are looking for just the wheel, not worth it in my opinion. just read up on all of the reviews of the batmowheel. at first it seems like it is good but then as more tried it out and found out how hard it was to install and little to no gain said it was not worth it.
i doubt you will even notice the difference between stock and that one unless placebos work well on you
if you are looking for cheep performance, tuning is as close as you are going to get. after that you need to start saving up. what do you use now? have you tried Efi Live?
throttle response is pretty good on my 04 LB7. tuning pays a big part in it through the ECM and TCM
Old Jun 23, 2015 | 10:18 AM
FormerVendor
^^x2
Also, you can consider the Stealth 64 turbo. It is a drop in replacement that makes 600 RWHP consistently with stock injectors. A great match for any LB7 with a built transmission and a customer that is not ready to build the motor but does want to get the most out of it safely.
Old Jun 24, 2015 | 09:04 PM
Walker.B's Avatar
i haven't gotten EFI yet been doing a ton of repairs and upgrades to the suspension and other things im hoping to get the trans built then tuned and maybe a charger after that i know OD is weakish and my TQ converter feels a little loser the my buddys 04.5 LLY
Old Jun 24, 2015 | 10:22 PM
2004LB7's Avatar
I believe that the converters tightened up as the years went on. I think the LB7 has the same converter as the 8.1 gas rig. Also the more HP you make the looser the converter feels
Old Jun 24, 2015 | 10:36 PM
Walker.B's Avatar
its not like worn feeling just not "tight" but his trans only has 8K on it mine has 181K im not really worried about killing mine i never "dog it" in the higher tunes never past 3/4 fuel always in Tow/Hual NEVER in OD to scared to even run the cruise on the performance tune on my chip its like tow/eco (85hp) performance (115hp) extreme (180hp) all rated at the flywheel other mods CAI 5" straight pipe PPE boost valve Shimmed FPRV so im not sure what it really makes power wise itll kill a 6.0 without trying id just like it built for peace of mind
Old Oct 1, 2015 | 10:57 AM
2500HeavyDuty's Avatar
never use pensacola, run far far away. tried them once, swapped 4 sets of injectors in 2 months on my own truck
98cummins
For Sale
Jan 28, 2015 04:59 PM
David Scott
Wanted To Buy (WTB) - Used
Jan 21, 2015 10:27 PM
carid
Towing and Hauling
Oct 27, 2014 10:46 AM
Sculpturesylvan
Oct 18, 2014 10:40 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
