2006 cummins ecm cleaning help
Old May 29, 2015 | 10:12 AM
Zachbishop's Avatar
Default 2006 cummins ecm cleaning help
I have a 2006 5.9 CTD I have an intermittent camshaft performance CEL. I have replaced sensor , checked all grounds cleaned and replaced battery's and found out that when I press on the ecm harness on the block the code will go away for 30 miles or so Untill i wiggle the harness again. I'm assuming this means the wire is loose or I need to clean ecm. How do I do this? What will happen when I pull harness off ecm, what holds all wires in the harness? Please help , thanks
Old May 29, 2015 | 07:21 PM
dangerous1965's Avatar
JUST DISCONNECT YOUR BATTERIES AND THEN REMOVE THE BOLT IN THE MIDDLE OF THE CONNECTOR. Pull off and clean the assembly check for corroded or burnt pins. Most likely just a loose wire or broken wire. Use electronic cleaner good luck! At least your tach isn't jumping around and or not working!
Arog223
Aug 16, 2015 07:15 PM
jeremiah1
Jun 18, 2015 05:01 PM
regitan
Big Rigs & Semis
May 24, 2015 10:23 PM
PerformanceAuto
Jan 15, 2015 12:32 AM
Sbboozer
Nov 16, 2014 05:52 PM
