Ran great, then died
Old May 28, 2015 | 01:20 PM
kevfra's Avatar
Default Ran great, then died
This is a C-Series Cummins in a 1994 Class A motorhome. I fired it up the other day and it started Bang(!) right away like always. Ran for maybe five minutes, happy idle, then shut down. Won’t start again. It cranks great, tries hard, but not even a cough. No smoke. I suspect the fuel cutoff solenoid but I manually blocked it open and no difference. Here is one clue, as I crank there is no movement of the tachometer. Normally when cranking the tach will show a few hundred RPM but now nothing. Can’t find a single fuse or breaker that isn’t working. Ideas?
Old May 28, 2015 | 01:43 PM
Jet A Fuel's Avatar
I would imagine it probably has a mechanical injection pump correct? No electronics?
If so it may be a lift pump its hard to say might try a shot of ether and see if she fires. not to much though .
Old May 28, 2015 | 01:48 PM
kevfra's Avatar
It has a new lift pump, and new filters.
Old May 28, 2015 | 01:55 PM
Jet A Fuel's Avatar
Might check the crank sensor if the tach isn't moving.
Old May 28, 2015 | 02:01 PM
kevfra's Avatar
That's a thought. Is there a quick test for that?
Old May 28, 2015 | 02:07 PM
Jet A Fuel's Avatar
should get a k ohm reading of some kind you would have to locate it and unplug it.
check it with an ohm meter but i wouldn't think that would keep it from running if it has a mechanical injection pump.
taweste
Aug 29, 2015 02:34 PM
moose2j
Jun 21, 2015 12:36 AM
Mar 19, 2015 08:10 AM
dandbmcc
Mar 14, 2015 11:05 PM
RayRay4991
Feb 23, 2015 07:45 AM
