Edge insight cts
Old Apr 21, 2015 | 07:40 AM
Dr67's Avatar
Default Edge insight cts
Can anyone tell me if the edge insight cts will adjust the efi live in a 2008 cummins? I'm looking at delete kits and found a package deal on an efi live with 5" exhaust, sinister egr delete and edge insight cts was just wondering if it did more than just monitor everything. Thanks for any advice
Old Apr 29, 2015 | 04:27 PM
Motorops's Avatar
FormerVendor
Unfortunately that is only a function that is available on the 01-05 Duramax trucks. The nice thing is if you order a pass through CSP-5 switch you can connect the CTS monitor to the switch and the switch in the OBD-2 port and everything will function properly.
Old Apr 29, 2015 | 06:51 PM
Dr67's Avatar
So with the pass through switch the power levels can be adjusted on the fly and the cts will monitor everything as it should? Thanks for the info I really appreciate it
Old Apr 30, 2015 | 09:36 AM
Motorops's Avatar
FormerVendor
That is correct, you just need to make sure the CSP-5 switch that is purchased is a pass through style switch, then you can turn the dial to select the tune you wish to run, while the you monitor everything on the CTS monitor.
Old Apr 30, 2015 | 12:11 PM
Dr67's Avatar
That makes me feel better. Kinda new to doing this stuff. Thanks again
Old Apr 30, 2015 | 12:36 PM
Motorops's Avatar
FormerVendor
Not a problem at all
justinsbeck
Jan 18, 2016 12:15 AM
David4684
Aug 10, 2015 03:59 AM
Bowling_77
Feb 22, 2015 10:58 AM
somarillw
Dec 8, 2014 09:07 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
