84 f250 with 6.9 batteries going dead.
Old Apr 9, 2015 | 01:46 PM
greasesheik's Avatar
Default 84 f250 with 6.9 batteries going dead.
I have an 84 f250 with a 6.9 that seems to keep draining the batteries. Checked the batteries a day or two ago
and they was down to a little over 3 volts, checked them today down to .27 volts. The only thing I've done recently is change the starter. Could it be shorted out and draining the batteries or should I look elsewhere????
Old Apr 9, 2015 | 07:48 PM
j johnson's Avatar
if your sure nothing happened before the starter change then yes i would think the starter or wires around it..something could be pinched....scott
Old Apr 9, 2015 | 09:33 PM
RanchhandTCR's Avatar
First make sure your battery will charge to 12.5V or higher, second make sure you power wires or not touching a ground of any sort, second check for a parasetic draw.
06kyleP
Jul 19, 2015 06:10 AM
mudsmokinStroker
Ford Powerstroke 08-10 6.4L
Jun 29, 2015 02:19 AM
mpcampers
Dec 4, 2014 08:24 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
