1991 dodge 250 4X4
Old Mar 26, 2015 | 06:30 AM
rah32860's Avatar
Default 1991 dodge 250 4X4
I have a 1991 dodge 250, cummins turbo diesel, auto trans. Came factory with P235-16 tires and am now running P265-16 tires. It has 354 factory gears under it. Truck is basically factory stock with no modifications. The problem is that I can't keep a transmission in it. The transmission has overdrive on it. The overdrive always goes first. It seems like the truck is always in a constant pull. Do I need to change he ring and pinions to gear the truck lower to make it easier on the trans? If so what gear ratio do I need to put under it? Any help would be appreciated.
Old Apr 1, 2015 | 08:46 PM
KYLEBOY's Avatar
sounds like the kick down cable needs some adjustment, its shifting to a higher gear too soon
Old Apr 1, 2015 | 11:52 PM
dieselrick's Avatar
Have you replaced torque converter with transmissions? Has non lockup converter but if internals are damaged, could be cause. Now there is a throttle position sensor on top of inj pump throttleshaft that is adjustable and is main cause of no OD. Have only been successful around 10% of time w/adjustments. Need scan tool for adjustment or replacement. Should be scanned anyways for other problems that might be contributing. TPS is cheapest thru Cummins, LMK if you need pt #. Tire size diff not that big of deal.
Old Jul 24, 2015 | 01:02 PM
91DODGE4X4's Avatar
If it is your TPS there is a tps delete kit out there for 40 bucks that works great. From DNR Customs - Home
Old Jul 24, 2015 | 01:05 PM
91DODGE4X4's Avatar
Help! I need a new VSS for my 91 ram w250 4x4 . Any one know the best place to look?
Old Jul 25, 2015 | 11:11 AM
powermizer's Avatar
I like my non over drive 727
1990 w250 with over 300,000
never had a trans problem
change filter ever other year or 24,000 miles
rodbuilder
Jun 28, 2015 08:23 AM
river rat
May 18, 2015 05:04 PM
hoeky22
For Sale
Mar 15, 2015 08:35 PM
dezeldoc
Wanted To Buy (WTB) - Used
Jan 4, 2015 11:12 PM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
