Extremely Hard to Shift Lever from Park to a Drive Gear
Old Mar 25, 2015 | 09:47 AM
EverettsGMC's Avatar
Default Extremely Hard to Shift Lever from Park to a Drive Gear
I have a 2005 Dodge, 1 ton, 4x4 with a 5.9 engine and a 48RE automatic transmission. The problem I'm having is that I can barely shift the shift lever from Park to Drive or Reverse. The transmission works perfectly other than that as far as shifting automatically while driving. Is there a "linkage" issue that I can fix that someone knows about? Or is it internal? Looking for help on this one. Thanks
Old Mar 25, 2015 | 05:30 PM
akhappyjack's Avatar
Detent ball on the rooster comb in the valve body ie holds the trans manual valve in the correct position goerend transmission has the fix for it. Requires dropping the valve body
to correct
Old Mar 26, 2015 | 06:29 PM
AK Happy Jack - Thanks for your response to my dilemna. I did check out the goerend website and looked for the "fix" you referred me to. I did not see the part I believe you talked about. Any chance you could send me a direct link to the part or a part number? Thank you in advance.
Old Mar 26, 2015 | 07:47 PM
Default Found the Link for the Part
AK Happy Jack, I found the link on Goerend Transmission, Inc. - Torque Converters, Transmission website for the part you referred me to. Much appreciated!
Old Mar 28, 2015 | 06:55 PM
Bowman's Avatar
The company I work for also makes a repair for it...
Valve Body Detent Ball & Sleeve Kit - 22771-12K - Sonnax
Old Mar 29, 2015 | 12:08 PM
I've used sonnex boost valves and valve repair kits in the past also their big 2/4 servo for 4l60es and the 4l80es not much for the 48res as i've got 188k on mine I will be freshing it up soon
Old Mar 29, 2015 | 05:42 PM
Bowman's Avatar
Happy jack check the sonnax site out when you get ready to rebuild. We have some high performance stuff for the 48RE units. And a few more in development now.
alexcummins2341
Jul 31, 2015 11:21 PM
Mar 19, 2015 08:10 AM
aoutlaw95
Mar 3, 2015 09:02 PM
SixSpeed
Jan 11, 2015 01:41 AM
