Dpf code p2000
Old Mar 22, 2015 | 07:20 PM
fio diesel dog's Avatar
Default Dpf code p2000
Check engine light code is P2000 I'm new here and was hoping to find out if the Dpf delete exhaust system and the tuner I ordered will fix it? I've noticed a lag in acceleration at times. I have 137000 on my 2012 6.7. Any help?
Old Mar 22, 2015 | 10:16 PM
RanchhandTCR's Avatar
NOX trap efficency below normal, from what I know their was a recall to reflash for this code apperance, I would first call to see if their are any TSB calling for a reprogram to cure this code, next would be also the quality of def you are useing, def has a shelf life of 6-8 months, and these systems are so sensitive to how efficient the def is they will throw a code fairly easy. Or you have a NOx sensor issue or atd issue. But yes you can delete these systems but you need the proper ECM reflash or you will have a truck that is derated or will not start.
Old Mar 23, 2015 | 08:12 AM
Thank you my truck does not run def. i'm just wondering if it's only the DPF and once I eliminate that will be fine
Old Oct 20, 2015 | 05:24 PM
scubaman1's Avatar
I have a 2011 with 110,000 miles. I received P2000 and several other codes dealing with the EGR and exhaust. I put my truck in tow/haul mode and drove hard with the exhaust brake on for a few days. Codes cleared. In fact, when I would stop you could smell the buildup being burned off. No codes since.
Old Oct 20, 2015 | 10:04 PM
[QUOTE=scubaman1;1101009]I have a 2011 with 110,000 miles. I received P2000 and several other codes dealing with the EGR and exhaust. I put my truck in tow/haul mode and drove hard with the exhaust brake on for a few days. Codes cleared. In fact, when I would stop you could smell the buildup being burned off. No codes since.[/QUOTE. I got rid of the exhaust system tune it and added cold air intake Best money I have ever spent !!!!
Old Oct 20, 2015 | 10:08 PM
Got rid of the exhaust and tuned it added cold air intake. Now I get great mileage and runs so smooth
Old Jun 16, 2018 | 11:02 AM
megacabby's Avatar
Newbie and proud owner of a 2011 Ram 2500 Longhorn.
Since I’ve picked up the truck new in 2011, I gone to dealers and had the O2 sensors replaced 8 times and at times, resetting the Engine Light with a reader bought from eBay by myself as I could not be bothered going to the dealer.
Last week was when my GOLD Extended Warranty ended. Luckily, I reported the Engine Light coming on and again, the O2 sensors were replaced.
3 days later and after 400km, the Engine Light came on again.
I’ve tried running the truck hard by engaging the Toll Mode and Exhaust Brakes...that put the Engine Light out..Horray!
Note and from privous, the Engine Light would also go off and come back on. Hopefully driving the truck will keep the NAG off the dash.
We’ll report back in a week or if the light comes on prior.
Megacabby
Old Jun 17, 2018 | 02:03 PM
megacabby's Avatar
Default P2000 Code is Back
BAD NEWS....
It felt great as the Engine Light was gone. This afternoon unfortunately, the Engine Light came back on.
Luckily I took the truck back to the dealer where the last set of O2 sensors were replaced under warranty on Saturday (June 16) and the Service Advisor booked me in for Wednesday afternoon.
Here’s hope, the dealer can get rid of the Service Engine NAG.
Megacabby
PNW_Steve
Ford Powerstroke 2011-Up 6.7L
10
Jun 27, 2017 04:41 PM
stillcummin
Feb 18, 2016 08:13 PM
FarmDiesel
6.7L Performance
21
Apr 17, 2012 11:35 AM
funhauler
6.7L Performance
May 26, 2009 08:34 PM
Az2500Cummins
6.7L Performance
Dec 11, 2008 07:35 PM
