low oil pressure
Old Feb 22, 2015 | 11:05 PM
Ruddedawg5.9's Avatar
Question low oil pressure
Hey guys so I bought my first dodge D250 3 weeks ago and I started to look at my oil gauge on my cluster and I was seeing that my oil pressure was dropping it would rise up a bit and drop down again. The engine has 300k already and runs great but the low oil pressure concerns me can you please help.
Old Feb 27, 2015 | 12:41 PM
cumminsblazer's Avatar
Is the oil pressure dropping once the truck is warm cause mine cold at idle is like 50 psi and warm its more around 30 if I remember right
Old Feb 28, 2015 | 12:11 PM
Yea man, at first when I start her up its ok but when she's warmed up she'll start dropping the oil pressure
Old Mar 1, 2015 | 05:17 PM
AHolt's Avatar
Sounds like your oil pump is on its way out.
Old Mar 1, 2015 | 09:16 PM
ID Shopteacher's Avatar
I would hook up an oil pressure gauge on top of the filter housing using the small 1/4 inch plug hole just to see what your real pressure drop is! I have seen bad oil sending units, but it is hard to say if you are not familiar with the engine history ! Change the oil and filter and recheck with the external gauge ! Good luck !
soco
Jul 27, 2015 06:06 PM
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
