Turboing a 7.3 idi
Old Jan 26, 2015 | 08:02 PM
Jakecastellucci's Avatar
Default Turboing a 7.3 idi
I wanna turbo my idi its a 1993 7.3. Injector pump turned up a 1/4 turn. I would like to know how much boost it can run safely and what all I need to turbo it.
Old Jan 31, 2015 | 12:29 AM
4x4manonbroke's Avatar
Its not the boost you need to be careful of its cylinder and exhaust temps .. put a Pyro on your truck and drive it for a bit ..
another big help is a bigger exhaust and larger free flowing air cleaner .. mine was 14"X 6" K&N ..
if you go tossing a turbo on it your gonna run into a few issues ..
#1 ... there just isn't enough flow potential to make huge power in these engines
#2 .. your gonna spend more that your comfy with to get it all done
#3... If you slam a 12V in it .. Your WAAAYYYY ahead of the curve .. and you could run the 5 spd or the 4 spd for a bit before you need to swap it out .
take it from a guy who spent 4 years making my truck faster only to kill the engine all together ... 21:1 compression ratio wont support much boost pressure added ..
the N/A engines have smaller wrist pins and rods than the turbo engines ...
Old Jan 31, 2015 | 01:20 AM
Thanks an. What problems occurred an what should I avoid while turbo ing my idi. Ok not to go over 15 psi unless I update the rods an that stuff
Old Feb 9, 2015 | 08:09 PM
6.2idi nut's Avatar
If you want to turbo your 7.3idi go to this website www.R&DIDIPerformance.com
Old Apr 2, 2015 | 11:45 AM
Jellybelly801's Avatar
Default Issues
I recently got a banks kit, dropped truck off and they told me my valves are going, now the problem is i can do the work and fix the valves but what else is gonna come to play when the head is off. From my understanding these n/a engines aren't meant for a turbo. There are things you can do to support the system but I'm petty sure saving that money and getting a different maybe f/I truck. But when you love these classics it's worth doing it.
Old Apr 2, 2015 | 05:15 PM
6.2idi nut's Avatar
If you need some advice feel free to call me at this number (402)367-9080 Cell, If no ansewer please leave a message and i will get back to you.
Old May 18, 2015 | 11:51 AM
redtourist's Avatar
R&D IDI Performance Sure works better, goes right to R&D ididperformance site
Browe347
Dec 11, 2016 02:59 PM
Nick91
May 11, 2015 11:52 AM
Toms73
Mar 25, 2015 04:36 AM
Toms73
Mar 23, 2015 08:31 PM
Browe347
Sep 30, 2014 11:35 PM
