01 dodge cummins starting issues
Old Jan 26, 2015 | 03:24 PM
rschriek's Avatar
Default 01 dodge cummins starting issues
2001 dodge ram 2500 no start starts in high gear (the transmission) automatic wait to start lamp comes on real quick then turns off. I had a ton of trans codes and a low charge code and a few others, I replaced the injection pump and I got a code p0230 and a no start. I screwed around for a while and grounded terminal 1 on injection pump black and white wire. truck started right up. once ground removed truck would die. I know it runs to the ecm it sends a negative signal to the injection pump. while running truck would start in high gear still had plenty of power but alternator still won't charge. I think bad computer I order refurbished Pcm. But wonder If my Ecm is bad as well. Ecm is like $1000. any help would be great
Old Jan 31, 2015 | 07:47 AM
SD550's Avatar
I'd be getting a wiring diagram and checking the B+ and ground wires at the ECM before I went throwing parts at it.
Old Feb 3, 2015 | 10:13 AM
rschriek's Avatar
the ground wire on the injection pump was bad you were right
hurriedcoyte
Jun 19, 2015 06:26 AM
DSM1988
Jan 25, 2015 07:23 PM
Linkbeltpower
For Sale
Dec 16, 2014 08:44 AM
Linkbeltpower
For Sale
Dec 15, 2014 10:52 PM
Nov 4, 2014 08:10 AM
