Help!!! Clutch?? Slave Cylinder??
Old Jan 12, 2015 | 07:27 PM
Kennyw250's Avatar
Default Help!!! Clutch?? Slave Cylinder??
My 93 cummins will not go into gear while the truck is running it's a five speed, I think it's the clutch but it could be the slave cylinder has failed also, however there is fluid in the reservoir and it is not leaking.. I heard the slave cylinder can fail when fluids bypass the pistons and you can't see any leakage... Just wondering if anyone has had this problem before thanks
Old Jan 13, 2015 | 12:32 PM
detroitdiesel idi's Avatar
Slave cylinder for sure
Old Jan 13, 2015 | 06:04 PM
Kennyw250's Avatar
How can you be sure?? There's a possibility it could be the clutch right??
Old Jan 14, 2015 | 07:47 PM
BC it won't go into gear at all usually if clutch is going you can get it in sometimes and besides y wouldn't you replace a $50 slave before pulling the trans and putting in a $400 clutch kit. I'd do the 50$ n less labor first even if thts not the problem somehow if clutch is junk then the slave will fail shortly after from my personal experience
ILLUSHA
Diesel Engine Conversions
10
Aug 21, 2015 05:48 AM
Turbo67
Jul 25, 2015 02:26 PM
ford_man
Feb 21, 2015 10:59 AM
Oct 31, 2014 08:10 AM
91 7three
Oct 15, 2014 12:57 PM
