Need help about white smoke?
Old Dec 28, 2014 | 09:03 AM
Supremedragonx's Avatar
Default Need help about white smoke?
It was cold weather outside 30f . Idle then drive push hard gas did see mirror blow white smoke out of exhaust when 140f but when normal temp 195 non smoke white. Black smoke out . Any idea?
Old Dec 28, 2014 | 09:11 AM
Forget to say deleted dpf&unix. Unplug egr, egr cooler and so .
Old Dec 28, 2014 | 12:26 PM
AHolt's Avatar
In the winter when I start, always white smoke. It goes away after awhile.
Old Dec 29, 2014 | 08:03 AM
coors_man_2005's Avatar
Its normal when they are cold to white smoke if your driving it hard when its cold be prepared for head gasket failures. Or just other failures in general
Old Dec 29, 2014 | 09:14 AM
Motorops's Avatar
FormerVendor
Typically when it is cold out you will see some white smoke at times. That temperature definitely seems normal.
Make sure you are good on coolant and truck doesn't overheat. truck idle smooth?
Old Jan 4, 2015 | 06:40 PM
Good coolant no overheat . Idle smooth bit but need new belt & belt tenisor too . 195-200 . Cold weather idle park like 160 to 170 . If stopped park stay high idle high keep 195f
Old Jan 5, 2015 | 08:15 PM
Your golden. No worries
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sgreen3
Feb 24, 2015 03:34 PM
zoomer10h
Feb 6, 2015 01:38 AM
