Stock clutch replacement
Old Dec 13, 2014 | 11:02 PM
South Texas Goat's Avatar
Default Stock clutch replacement
I have 218xxxx on the original, what is the best replacement? I only run the tow mode on my programmer so won't need any crazy hp holding. 2005 6spd NV trans
Old Dec 16, 2014 | 07:20 PM
dieseldean's Avatar
I would just go with o.e.m. I upgraded mine at 179,000 miles with a south bend kit. Came with hydraulic kit, and all rotating assembly. I followed the break in instructions, and it still doesn't hook up. When I questioned the shop that did the work, They said they would check it out but I had to pay the labor. They said south bend would not return their calls. The o.e.m. clutch worked fine, the linings were in good shape, but the springs were shot. hope that helps...
Old Dec 23, 2014 | 07:12 PM
Clutch is in, low pedal and way soft. They must have let air in the hydraulics...back to the parts house. Change the master cylinder and see if that puts it back right...
Old Dec 24, 2014 | 09:01 PM
Did the trick, back in business
Old Dec 30, 2014 | 11:44 AM
Low_Life_Style's Avatar
katman
5.9L CR Performance
Sep 10, 2015 03:34 AM
Turbo67
Jul 25, 2015 02:26 PM
kryz9903
Jul 2, 2015 06:14 AM
boostkid
Jun 3, 2015 11:16 PM
Wyocumins
Oct 19, 2014 09:34 PM
