VE pump will NOT adjust!!!
Old Dec 6, 2014 | 06:25 PM
93cummins12v's Avatar
Default VE pump will NOT adjust!!!
So basically i have done every adjustment possible to this VE pump and nothing works. I have turned the full power screw, the smoke screw..etc. The pump does not deliver any extra fuel. After the the injector install i can see the difference in power but it screaming for more fuel. i have the power adjustment screw bottomed out and there is no change in idle while moving the screw in.(or out). I took some pics while i was putting the GSK in the pump internally looks the same as other pumps i have seen. On the TST web page for adjusting the VE pump they mention that some trucks cannot be turned up by making the adjustments. I was wondering if anyone has every encountered this or am i the only lucky one.
Old Dec 6, 2014 | 11:07 PM
dan123dbl's Avatar
Are you sure you're turning the correct screw? Do you have any pictures? If you unscrew the power screw it should drop your idle and eventually not run / start. It pushes against the fulcrum lever inside your pump.
Old Dec 15, 2014 | 01:01 PM
Yes at some point backing the screw out the truck dies but once you start back in the idle will go back to normal and never go higher.. And yes I'm turning the right screw I've turned other pumps up no problems
Old Dec 16, 2014 | 11:08 PM
dan123dbl's Avatar
That's odd. You might need a longer fuel screw then. Try "The Hot Screw" from The Hungry Diesel. Should solve your problem
Old Dec 16, 2014 | 11:52 PM
novapat's Avatar
could have a broken spring, cam flat in inj. pump or rotor head worn and wont build any more pressure..
Old Dec 17, 2014 | 08:51 AM
Thanks I'll try the hot screw and let you know I don't think the pump is worn although it could be possible I'll let you all know of I find any solutions
Old Dec 22, 2014 | 11:06 PM
dan123dbl's Avatar
Some pumps have been known not to use their full fuelling capabilities with the factory power screw.
Let us know if the hot screw works
Make sure to be prepared for runnaway
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
