ve pump leak?
Old Nov 17, 2014 | 07:49 PM
NHenry166's Avatar
Default ve pump leak?
Hi guys I'm new to the site and I just got this truck and it's in pretty great shape. But it is leaking a small amount of fuel from the pump. It looks like it's coming from where the fuel screw is. Is there an o ring there or some kind of way of sealing it. Or is it somsomething else.
Any help would be appreciated
Old Nov 21, 2014 | 04:32 PM
Redtruck-VA's Avatar
Subscribed...
Old Nov 30, 2014 | 10:38 PM
cumminsblazer's Avatar
If you are talking about your full fuel screw then yes there is check out the sticky before you go play with that though
Old Dec 10, 2014 | 06:33 PM
big tan snorkel's Avatar
http://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/repair-leaking-fuel-pin-153154/?styleid=11
Go to this website, this is your problem, I had the same problem a while back
Old Dec 10, 2014 | 06:34 PM
And if it's the fuel screw use plumbers tape on the scene then put the nut on over it to seal it, sometimes the threads get soft and allow a small leak pask, use plumbers tape
Old Dec 17, 2014 | 03:14 AM
If you have the pin out replace the o ring I wouldnt rely on teflon tape like I think big tan snorkel was talking about with plumbers tape ( plumbers tape what holds your water heater to the wall with all the holes in it)
Old Dec 17, 2014 | 04:13 AM
Not meaning to bash back blazer, but I have found it works for sealing thread gap, but yes replace the o ring, but you might have to go to a rubber specific store for a fuel safe o ring so you don't run into the o ring getting eaten off
Old Dec 17, 2014 | 01:39 PM
I agree maybe in a pinch like leaking bad and need to go to work in the morning through some teflon tape on there and go to work but its not like a npt thread teflon will start leaking again cause its not getting smashed in there
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
southern dieselnorth zip
May 18, 2015 01:02 AM
ItsAChummins
May 15, 2015 05:02 PM
mpcampers
Dec 4, 2014 08:24 PM
Gizmo52
Oct 27, 2014 07:32 PM
