What's the easiest way to bleed the fuel system
Fill your fuel filter with ATF .. Crack 4 injector lines .. cranktill you see fuel at any one of them and then close that one .. do this tiits running ( Plant your foot to the floor and the IP will move more fuel ) ...
Most people that recommend ATF are "old timers" modern ATF is nothing like it used to be. The new ATF compaction yes is still in oil yes still A detergent but it is not designed to burn and will leave an ashy substance left behind in the end. ATF also has very strong friction materials in it designed for the cluch paks in automatic transmissions. With fuel pumps and systems having such tight tolerances it is strongly not recommend
Just my $0.02
Just my $0.02
Just my $0.02
Just my $0.02
.. Lubrication is key
