what vehicles can i pull a lift pump from?
Old Oct 30, 2014 | 11:26 PM
james2562's Avatar
Default what vehicles can i pull a lift pump from?
I know a 93 LP 6.5 diesel has a better lift pump. I want to go down to the bone yard and pull a LP. can i pull from any year 6.5 diesel? Can i pull from a 6.2? will a GM gas truck work?
Old Oct 31, 2014 | 05:57 AM
Mayhem's Avatar
Chevy gas burners have their fuel pumps in the tank not to mention they make higher fuel pressures than a 6.5 can handle.
Old Nov 1, 2014 | 08:56 AM
turbodiesel123's Avatar
I've heard of someone using a lift pump off a 6.2 on their 6.5
Old Nov 1, 2014 | 03:18 PM
Mayhem's Avatar
1993 is the year lift pump you want as they had the highest pressure available.
Old Nov 2, 2014 | 08:31 AM
racer55's Avatar
All 6.5 equipped trucks will have the same physical dimension frame mount electric lift pump and can be swapped in place of any other.
That said you are already aware that AC Delco: EP158(1993 model year Lift Pump)is the best factory replacement available.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
