Bleeding/priming 6.5 diesel
Old Sep 24, 2014 | 03:59 PM
1MooseheadPlease's Avatar
Default Bleeding/priming 6.5 diesel
I had to replace the lines from the tank to lift pump , they were leaking badly. I dropped the tank and replaced the fuel sending unit in tank as well, removing the In-line fuel pump I broke it... So I bought a new one of those to ,got it all back together ,now just wondering how you prime it , I've searched a few times found some threads , t-screw at the front and the bleeder screw on top of the fuel filter , I also jumped the fuel pump relay had it running for an hour or so... Been 2-3 days still no luck
is fuel supposed to come out of the top of the fuel filter screw ?
Sorry in advance if my story is jumbled ,
Old Sep 24, 2014 | 05:52 PM
burnhedge's Avatar
Yes you should be getting fuel out the top of the filter if the screw is open and the LP is running.
I jump power to the LP, bleed the filter then through the t valve. Your injector lines should self bleed once you start cranking but I always crack a line at the injector to speed it up.
Old Oct 1, 2014 | 06:54 AM
racer55's Avatar
To activate the lift pump look for a single red wire with an insulator just behind the underhood fusebox.
Apply 12v to that wire and the LP should run when the relay is properly in it's place.
Open the bleed valve on top of the fuel filter and keep it open while the LP is running until air quits coming out and a steady stream of fuel is present.
The integral cap fuel filters have issues with that bleed valve and some only bleed around the threads and not out the top of the valve.
As mentioned I also like to have an injector high pressure line loose while bleeding the high pressure side.
Old Oct 1, 2014 | 07:18 AM
Thanks for the help ,somehow i had the LP in backwards .. Flipped it around works great
Brclouse
Nov 18, 2015 08:44 AM
JohnFromVt
Aug 3, 2015 06:15 PM
Easton18t
Jul 30, 2015 02:06 PM
JamesL91
Mar 15, 2015 06:11 PM
Snoobly
Dec 11, 2014 11:59 AM
