Timing question
Old Sep 22, 2014 | 06:40 PM
City Guy's Avatar
Default Timing question
Does anyone know if it is possible for the IP gear (1990 6BT) to jump teeth when R&Ring the IP? Or is it too close to the top of the timing case.
Old Oct 2, 2014 | 04:26 PM
Rx7man's Avatar
In my 94 engine it was too close, and I think as far as clearances go they're all the same.
Old Oct 3, 2014 | 03:12 PM
City Guy's Avatar
I was afraid you would say that. I have one that seems to be lacking enough timing advance. IP pushed as far advance as it will go and it is sluggish, smokes and is generally unhappy, but if I turn on the KSB(its on a toggle) it runs great. I guess the front cover needs to come off. Thanks for the input.
CG
Old Oct 3, 2014 | 03:38 PM
Rx7man's Avatar
I guess if you prefer, you could take the IP off again and make it jump back to the right place again, if you can't make it jump, I guess it couldn't have come out?
Old Oct 6, 2014 | 09:41 AM
City Guy's Avatar
I thought about that too. Pondering on which way to go.
Old Oct 7, 2014 | 02:22 PM
Rx7man's Avatar
If you do it from the front cover, put a new gasket and front main seal and eliminate ONE place for oil leaks..
Does it start easily, just sounds labored?
I'm not too familiar with the 93's, but is there a window on the pump where you can get an alignment mark and check it against the cam pin or something before you take it off again?
Is it possible that there's something wrong in the KSB when you don't have it on manually?
Old Oct 7, 2014 | 02:32 PM
Rx7man's Avatar
I just did some research on it.. did you replace the IP with a different one? It may have been an older one and they work in reverse (change took place with the addition of the intercooler it sounds like)
I got my info from here
what is a ksb - Dodge Cummins Diesel Forum
Old Oct 7, 2014 | 03:05 PM
City Guy's Avatar
I think I have a couple of other gremlins at work. It is loosing the prime after it sits for 10-12 hours and you have to crank it for about 10 seconds to get it started. It has the later model KSB (power turns it on) the truck is a 90 and had the wax motor KSB (power turns it off) hence the toggle to control it. I installed clear lines on the fuel supply and return last night and it has a very small amount of air in the return line. In the process of removing/deleting the fuel heater. I'll let you know what I find. Thanks.
Old Oct 7, 2014 | 04:08 PM
Rx7man's Avatar
That's a good start for the prime issue, a lot of them will leak at the connecting pins.
As for the timing, I'm not sure about the VE pumps, but P pumps can had different amounts of timing 'built in'.. With the VE I guess it would be a different indexing on the shaft. Not all that likely, but a vague possibility.
Old Oct 14, 2014 | 03:34 PM
City Guy's Avatar
Well, I deleted the fuel heater bleed the air out and got it running drove it around a bit. Parked it and took off for the weekend on the bike. It sat for about 50 hours and started right up. Then it sat last night and it didn't want to fire this morning. Back to the old drawing board I guess.
I put the timing question up on the diesel garage forum and one guy said the gear can jump. Tonight I'll try and see if I can see the marks on the gear somehow.
quiksilver1j
Jul 30, 2015 12:41 PM
cummins Pride
Dec 31, 2014 12:58 PM
12vdriver21
Dec 29, 2014 07:46 AM
SMatyac
Nov 15, 2014 07:35 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
