215 injectors with a 160 pump
Old Sep 22, 2014 | 02:05 AM
Slim Whitey's Avatar
Default 215 injectors with a 160 pump
Is this gonna work? Will a set of injectors for a 215hp 6bt run that extra 55hp when bolted to a truck with an OEM pump from a 95 auto (160hp)?
Or am I looking at mucking with the pump to get it to feed those injectors? I figure a good start on 250 rwhp when a guy already needs injectors is to...well....get better ones. These are new from Cummins for 190 bucks. I cannot complain.
Old Sep 22, 2014 | 12:23 PM
4x4manonbroke's Avatar
They will work .. You will need more fuel pressure @ IP .. by using an adjustable Overflow Valve you can tune it in ..
Old Sep 22, 2014 | 03:46 PM
The only difference between a 215 and a 160 pump is a 32 dollar aftermarket overflow valve?
Old Sep 22, 2014 | 06:33 PM
NO .. The difference is the amount of flow and the injector hole size ...
Like 5x8= 5 hole .. .08" injection hole
or 5x16 = 5 hole .. .016" holes .
the bigger the holes .. the more the injector will flow = more bang = more power
Old Sep 22, 2014 | 07:03 PM
Yes I realize that. But I have injectors figured.
I was only referencing the 160 pump compared to the 215 pump. If the flow difference can be made up with an overflow valve, is that it?
Old Sep 22, 2014 | 08:07 PM
No u need , OFV, DV's, and the major difference is in the cam profile of the 215 vs 16-180 pumps ..
Old Sep 22, 2014 | 08:30 PM
Damn....thought I could just get the 215 injectors and the overflow haha. Never that simple.
Old Sep 22, 2014 | 09:18 PM
dezeldoc's Avatar
They will work just as it is, no need to touch the pump. put them in and have fun.
Old Sep 23, 2014 | 04:36 PM
Well if you needed more pressure and if you wanted a tad more flow .. you can go with bigger DV's and the 215 inj's will work even better .. mt $.02
Old Sep 23, 2014 | 06:10 PM
94 12valve's Avatar
for the goals you listed they will work just fine
