Newbie NL needs Help
Old Sep 20, 2014 | 05:49 PM
NLTrek's Avatar
Question Newbie NL needs Help
Have a '96 GMC/Chevy 6.5L Turbo Charged Motor Home.
Have noticed over the summer that I have a Starting Problem when engine is warm to hot.
Must use a mechanic because I am not physically able or familiar with diesel engines.
Besides, this one has SO many electronic governors, sensors and plug-ins, that I have No
Clue. I am currently traveling away from home and need to choose a mechanic/shop, but I think most I have contacted are less than knowledgeable. Talking to me about Starters, Ignition Switches and even batteries, when they Don't Listen to the sequence of events.
so, I am hoping that the people of DieselBombers can lend me some assistance.
Thanks in Advance!
Old Sep 22, 2014 | 09:59 AM
racer55's Avatar
These engines need a good set of batteries 750+ CCA(cold cranking amps)and a good starter to spin them fast enough to start.
That said hot start problems often come down to wear on the IP that is made worse if the lift pump is not operating.
Next time you try to hot start the engine try pouring water over the injection pump before starting and note what difference if any occurs?
If it starts just as though it were cold you have an answer-it needs an injection pump(IP).
There are a great many low quality IP rebuilders out there so research by price then by reputation-all the bad news hits the internet but much less of the good news so the fewer posts about a vendor the better they likely are?
Rescuedu
Aug 26, 2015 05:38 PM
AmberAlert69
Aug 23, 2015 09:02 AM
Mopar92
Jan 24, 2015 08:54 PM
ilovetacos
Dec 10, 2014 12:55 PM
plow_this
Nov 16, 2014 11:40 PM
