Sport trac 2.8l cummins
Old Sep 18, 2014 | 01:36 PM
Rangmar's Avatar
Default Sport trac 2.8l cummins
Ok so I found this sport trac and couldn't pass it up. It has 115000 miles and the timing chain broke. So ill be continuing the swap I was doing on the ranger here. The motor is a 2.8l direct injected wet sleeved with a ve injector pump. The trans will either be a m5r2 from a 1997+ f150 or a aod from a older f150 or bronco I haven't decided yet. Here are some pic of what I have so far.Name:  imagejpg7_zpsdc39e22d.jpg
Size:  81.5 KBName:  imagejpg2_zps06f78e6a.jpg
Size:  127.6 KBName:  imagejpg1_zpsf5250e60.jpg
Size:  129.6 KBName:  imagejpg4_zpsa52dd712.jpg
Size:  84.3 KBName:  imagejpg1_zps0fb5bbfa.jpg
Size:  86.6 KBName:  imagejpg3_zps197800de.jpg
Size:  88.1 KBName:  imagejpg3_zps78aa05f0.jpg
Size:  107.0 KBName:  imagejpg5_zps2536d963.jpg
Size:  69.2 KBName:  imagejpg6_zps6953375c.jpg
Size:  105.7 KBName:  imagejpg6_zpsb35b279b.jpg
Size:  111.3 KBredneck leakdown test #3 couldn't hold anything Name:  imagejpg4_zpsd6f758c9.jpg
Size:  132.1 KBName:  imagejpg2_zpsab93d910.jpg
Size:  61.5 KBName:  imagejpg1_zpsed42c764.jpg
Size:  85.9 KBName:  imagejpg3_zpsca167d16.jpg
So this is where I'm at now. About half my rebuild parts are in ill post more pics when they come in
Old Sep 18, 2014 | 08:08 PM
Freedom92's Avatar
That's going to be a cool swap. Is it a 2wd or 4wd? I don't remember if you mentioned that. Looking ahead to my next endeavor I'm looking at a Jeep Liberty with the Kubota
Old Sep 18, 2014 | 11:26 PM
Rangmar's Avatar
It is 4x4. I think a liberty would be alot of fun with a v2203
Old Sep 19, 2014 | 07:23 AM
Freedom92's Avatar
I'm going to have to do a little research though. One to make sure it will fit which I think it will and two...to get the automatic transmission to function with the kubota. Should be enough jeep gurus out there to steer me straight.
How would you go about adapting a non electronic tranny to that transfer case in that sport trac? Or could you go to an older t-case as well
Old Sep 23, 2014 | 11:01 PM
Rangmar's Avatar
Well it looks like I'm going auto. If I use a aod the od is .66 and with the tires on it its perfect with my 4.10 rear gears. 1800 at 61 mph and 71 mph at 2100 and I won't have to spend money on a trans controler. The factor stall on the aod converter is 1600-1800 so should be perfect for my motor. My torque spikes at 1800 and peaks at 2200. And better yet the f150 4406 transfercase will fit without cutting the fram and the front drive shaft will fit with a 1330 unjoint and. The 5.0 explorer crossmember will bolt right up to the aod!Name:  imagejpg1_zpsd2d37f8f.jpg
Old Sep 26, 2014 | 11:35 PM
Rangmar's Avatar
Bought my intercooler tonight! I hate spending money but it will be nice to havin to spend so much time tring to make I tear cooler lines
http://www.ebay.com/itm/380910905508?_trksid=p2054900.m570.l4467&_trkparms=gh1g%3DI380910905508.N19.S2.M0.R1.TR4.R1.TR4
Old Sep 27, 2014 | 09:25 AM
yellow68gto's Avatar
That's a nice kit. I plan on a similar one but with a different intercooler.
Old Sep 27, 2014 | 08:29 PM
Rangmar's Avatar
Thanks. I would rather have a larger one but I really don't want to cut my radiator support up. So ill run this one up high behind the grill and another one I have down low between the recovery hooks. So instead of returning through the engine bay it will loop behind the bumper and return passenger side/ same side
Old Sep 30, 2014 | 06:53 PM
Rangmar's Avatar
Well I got a great deal on my trans. 83 bucks withs converter flex plate dust shield and. Tv cable. It looks to have been rebuilt
Old Oct 2, 2014 | 01:52 PM
Freedom92's Avatar
Do you think this transmission and transfer case setup would work behind the kubota in a ranger?
I've also been pondering a transverse mounted kubota in a ford escape wondering g what the possibilities would be there. The axle ratios are 2.91 and if the motor would fit that could be a mileage king!
