Can I swap just injector coils?
Old Aug 8, 2014 | 05:50 PM
bpetricek's Avatar
Default Can I swap just injector coils?
I have a 95 e350 shuttle bus. Getting High to low side short codes on cylinder 1 2 3 and 8. Getting very low resistance readings on the injector coils. Apparently The fcim failed under the previous owner, and was replaced. I feel as if the coils on top of the injector was fried by the previous fcim failure and was wondering if I can swap just the solenoids on top of the injectors.
Old Aug 8, 2014 | 06:23 PM
joebob3093's Avatar
Moderator
you mean the solenoids? also there is no ficm on the 7.3. the ficm is a 6.0 thing, the 7.3 has an IDM. i think you can swap them with another set but im not 100% sure.
Old Aug 8, 2014 | 07:12 PM
autostroker's Avatar
I would change out valve cover gaskets first and see if that cures it. The wiring is known for burning up in the valve cover gaskets.
Sent from my SCH-I545 using Tapatalk
STDiesel59
Jul 11, 2015 10:09 AM
Beau_Jacques
Jun 26, 2015 12:17 PM
F250MACH
Apr 26, 2015 05:19 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
Jgloveracob
Nov 16, 2014 07:27 AM
