Chevy/GMC Duramax 07.5 -10 LMM Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines
after towing fuel filter goes to 0%
Old Aug 6, 2014 | 05:47 AM
sha.leavins's Avatar
Default after towing fuel filter goes to 0%
Hi.
After i get home from towing my camper. The next morning my fuel filter went from 94% to 0 and said change filter. Shop over the phone said it must be injectors. Have a hard time be living this. It has happen twice. The filter was about 1 month old. Dident go into limp mode. And dident happen while towing. Was the next morning both times. Reset the counter. Stayed fine. Any thoughts?
Old Aug 7, 2014 | 10:40 PM
2004LB7's Avatar
I would look to see if you have any fuel line restrictions such as a kinked line, collapsed line, etc. Also look into the pressure relief valve to see if it may be leaking. Basically anything that may lower the fuel pressure. Even a small air leak may do it.
From my understanding the ECM doesn't just look at the miles driven but also factors in the fuel pressure during various conditions and it constantly sees the actual pressure lagging behind the desired pressure then it starts to drop the remaining life faster.
Old Aug 8, 2014 | 08:48 PM
Thanks. I read everything i could and found nothing that said bad injectors. Hard for me to be live that a shop can be sure its injectors an tell me 5 k to fix with out seeing the truck
Old Oct 9, 2014 | 09:09 AM
Motorops's Avatar
FormerVendor
Does this truck have any tuning? Also does this truck have a lift pump?
Old Oct 9, 2014 | 10:08 AM
Tuneing yes, modzilla, lift pump no. Running small tune
Old Oct 9, 2014 | 11:51 AM
Motorops's Avatar
FormerVendor
Seems the truck is running low on rail pressure drying the fuel filter out that is why your getting that code to pop up.
Old Oct 9, 2014 | 12:18 PM
I agree but why or how worried should i be. It hasent done it in over a month and it only happens after he tow a heavy load
Old Oct 9, 2014 | 01:34 PM
Motorops's Avatar
FormerVendor
yea, typically it will do it under a load. I can't say what the truck is doing if it is dropping rail pressure while driving empty but i would recommend a Lift pump to ensure you are good to go.
Old Oct 9, 2014 | 03:01 PM
2004LB7's Avatar
Have you checked your black rubber fuel lines coming out of the filter and running to the CP3 yet? Enteraly collapsed lines, kinked lines, etc will lower the fuel pressure and the ECM will treat it as a clogged filter. Air leaks will do the same thing. As mentioned above, verify these are in good working order
Old Oct 14, 2014 | 09:00 AM
Motorops's Avatar
FormerVendor
Any update on this issue?
jeffersonl
Nov 15, 2015 07:35 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
