6.2/6.5 hybrid build
Old Jul 22, 2014 | 09:40 PM
ausbaker6624's Avatar
Default 6.2/6.5 hybrid build
I am thinking about doing the 6.2 hybrid build to my truck. I have a 88 6.2. I was just wondering what all I would need from a 6.5 to do it. Also is there anything I would have to custom make to make the swap work
Old Jul 24, 2014 | 09:32 AM
racer55's Avatar
Use the 6.5 precups,injectors manifolds and frt drive accessories and 6.2 everything else.
Get the lubrication specialists or Leroy diesel oil cooler kit.
Also would be a good time to add EGT gauge and boost gauge,might also go with turbomaster for reliability and OPS relay mod depending on year of 6.5?
New balancer and drive pulley at the same time along with diamond eye exhaust.
Old Jul 24, 2014 | 09:59 AM
Would it just be easier to do a top end from a 6.5? And how much boost should I run to be safe
Old Jul 26, 2014 | 08:21 AM
racer55's Avatar
Sure if your heads are in good shape,go ahead and use them.
Max boost with stock ECM and electronic IP is 10 psi before coding.
with mechanical IP max boost is 15 psi but requires intercooler or water injection.
Limit boost to 12 psi would be my target.
mike71800b
Aug 18, 2015 03:50 PM
Mar 19, 2015 07:10 PM
DODGEARMYGUY
Feb 8, 2015 07:08 PM
jtwthaxj
Diesel Engine Conversions
Jan 14, 2015 06:52 AM
Dec 6, 2014 11:00 AM
