amatuer question
Old Jun 10, 2014 | 05:52 PM
TwinStaxx's Avatar
Default amatuer question
I just recently purchased 150hp injector nozzles.... Just wondering what it will do if I put them on stock injectors?
Old Jun 10, 2014 | 06:03 PM
RAW's Avatar
RAW
Injector bodies are injector bodies. Replacing the stock nozzle on the stock body with the 150 will give you your 150HP injectors. Get a diesel shop to do it so they can set the pop pressure.
Old Jun 10, 2014 | 10:54 PM
TwinStaxx's Avatar
Thanks for info also one other issue I'm having is I cannot get my truck to spool above 2300 rpm while braking and it will not turn tires over at all unless pavements wet
Old Jun 11, 2014 | 10:22 AM
RAW's Avatar
RAW
Torque management in the ECU will limit you power if you don't have mods or a programmer.
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
torg73
May 11, 2015 03:08 AM
99&91cummins
Mar 4, 2015 01:56 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
Oct 27, 2014 09:02 PM
