cummins trans problem
Old Jun 4, 2014 | 11:44 PM
kyle_cates's Avatar
Default cummins trans problem
i have a 2001 dodge cummins, it will shift 1-3 just fine but it wont shift out of third, if im driving 60 my rpms are t 2500 and a can feel the torque converter lock in but it still wont shift out if third... what could be my problem?
Old Jun 12, 2014 | 07:09 PM
4x4manonbroke's Avatar
Could be manny things, tps not giving the right signal, whats your fluid look like ?
Can you scan your truck ?
Old Jun 12, 2014 | 11:01 PM
gladeslife's Avatar
Do a search for grounding the overdrive wire. That's how I got mine to work.
Old Jun 15, 2014 | 01:53 PM
kyle_cates's Avatar
My fluid looks great, and I grounded my trans and it's still the same. Some people told me it could be my OD solenoid or my trans temp sensor, before I bought the truck the guy before me said he had some transmission work done to it, but I'm not sure what they did
Old Jun 15, 2014 | 02:38 PM
gladeslife's Avatar
You put it on a switch right? Yea that's the next step if the switch doesn't work assuming you grounded the right wire.
Old Jun 23, 2014 | 10:50 PM
kyle_cates's Avatar
Wait I just grounded the whole transmission not the wire, where exactly are the wires located on the transmission?
Old Jun 24, 2014 | 12:34 AM
kyle_cates's Avatar
And also I have no check engine lights on or anything like that
Old Jun 24, 2014 | 08:31 AM
kyle_cates's Avatar
Well I figured it out, I guess the people that owned the truck before me put some type of programmer on it that had to splice into the TPS wire, well when they took it off they just cut the wire and didn't splice the two original back togeather. Well that was the problem
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
signoremint
13
Oct 21, 2014 07:21 PM
