Turbo Troubles
Old May 28, 2014 | 02:10 PM
Noob's Avatar
Question Turbo Troubles
Hey all, first time poster here, long time lurker. The forums here have helped me quite a bit, but now i think i need some direct advice.
The other day i was driving down the highway when i lost all boost. My EGT jumped significantly and things got LOUD.
I popped the hood and saw that my waste gate actuator rod was just dangling around with the engine running.
I got it home, cut the top off the WGA and sure enough there was a tear in the diaphragm.
I use the WGA housing to make my own spring controlled WGA.
Problem is, now i still cant produce much boost, 1.2 - 3 TOPS. still VERY loud.
My next step was going to be pulling the turbo, is there anything i should be looking for? MY EGT got to 900 degrees, which i did not think to be fatally high. could i have put a hole in my headers or something? Any advice is much appreciated.
1999 K2500 suburban 6.5 TD PMD relocated to bumper. 250,000 miles.
Old May 30, 2014 | 09:34 AM
racer55's Avatar
Check the crossover pipe seals and the rest of the exhaust for holes.
Sounds like you need a stronger spring for your turbomaster-max boost should be 9 psi under hard acceleration.
1250F is max egt when taken pre turbo,for post turbo probe locations 900f is pretty much max.
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
