Injector pump and PMD location
Old May 19, 2014 | 07:20 PM
043506.06speed's Avatar
Default Injector pump and PMD location
a buddy has a 6.5 and think the PMD is giving him problems. I looked for the pump but not sure where it is. Is it next to / under the intake manifold? What is involved to change one?
Old May 21, 2014 | 10:43 AM
racer55's Avatar
Yest the IP is under the intake and in stock form the PMD is mounted on the drivers side of the IP.
The best approach is to by a PMD relocation kit that includes a new PMD,a PMD heatsink,PMD resistor and a 6' extension harness.
Then mount the PMD to the heatsink with heat transfer paste/pad between them,torque the mounting screws to 20-25"/lbs,install the PMD resistor in the harness cavity and mount the combo under/behind the frt bumper-then route the extension harness up to the factory PMD harness that you need to fish out from under the intake.
2 long screwdrivers and a coat hanger/hooked pick are required to undo the factor harness from the original PMD.
Pry the locking tab gently away from the PMD with 1 screwdriver and with the other push the harness back towards the firewall,then use a hook to pull the harness out where you can plug the extension in.
Joracing3
Sep 10, 2016 05:28 PM
98suburbandiesel6.5l
Jul 25, 2015 03:25 PM
petew
Jul 2, 2015 05:40 PM
JamesL91
Mar 15, 2015 06:11 PM
LTreis702
Nov 7, 2014 08:06 PM
