LMM Performance Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines Related To Performance And Longevity
DPF And EGR Question
Old Apr 28, 2008 | 11:35 PM
2006DURAMAX's Avatar
Default DPF And EGR Question
Hi, I'm new to the site. I currently have a 06 GMC LBZ, 4" turbo-back exhaust, afe Cold air intake, and edge with juice. I'm considering trading in for a 2008 chev LMM, but am afraid of all the emmissions garbage.
Is there a cat and dpf delete with the bungs so I can screw the sensors back in? If not what do you do with the sensors?
Can you turn off the regen with the LMM edge, if so will this stop it from going into regen mode?
Also how difficult is it to block the egr on the new LMM, I haven't looked under the hood of one yet.
Finally if I can delete the cat and dpf can I run LSD rather than ULSD, and can I use regular 15/40 oil rather than the "low ash" CJ-4 they recommend? Thanks any feedback would greatly be appreciated!
Old Apr 29, 2008 | 09:53 AM
Meyer Performance's Avatar
No you just take the sensors off the truck and as far as egr block i am not sure have not done that yet
Old Apr 29, 2008 | 10:06 AM
TCU Fan's Avatar
Aaron
It depends what you want to do with the truck, I have about 21K on my truck with the all the emission stuff still on it and have no problems with regens or clogged DPF.
Not 100% sure about what you can do with the edge because I am not a fan of the edge. I know with some you can (Quad and PPE).
AS Tyler said you just take the sensors off when you remove the DPF.
I would not run LSD, in fact I cannot remember seeing a place that sells it anymore.
Old Apr 29, 2008 | 05:55 PM
TEXASPOWER's Avatar
wt they said , but wen i had a dpf on it was constantly clogging
Old Oct 14, 2009 | 08:29 AM
DMAX86's Avatar
Everything is just bolts plus a capable tuner... just go for it! you can always put it back to stock.
RAW
6.7 Liter Dodge Cummins 2013+
9
Apr 17, 2017 02:36 PM
kestmic1
Jun 8, 2015 12:44 PM
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
Shmeldon22
Ford Powerstroke 08-10 6.4L
Dec 14, 2014 11:22 PM
