Upgrading from a C6 to a ZF-5-Speed w. 4x4 - Transfer case question
Old May 15, 2014 | 11:02 AM
Joerg's Avatar
Default Upgrading from a C6 to a ZF-5-Speed w. 4x4 - Transfer case question
Dear community,
i am planning to upgrade my 1988 F250 Diesel 4x4 from a c6 to a ZF 5-Speed.
Can I use the c6 transfer case or do I need one that fits the ZF?
Can I use my C6 crossmember, or do I have to get one especially for the ZF?
Any other advices highly appreciated :-)
Thanks.
Joerg
Old May 18, 2014 | 02:12 AM
Sycostang67's Avatar
You can use your original transfer case. When I did this swap, I used the cross member from the 5spd donor truck, but I had to elongate the bolt holes for the transmission mount and use the mount backwards.
Old May 18, 2014 | 03:33 PM
4x4manonbroke's Avatar
Hey J , what gears ya running ?
Old May 21, 2014 | 09:52 PM
Joerg's Avatar
I do have 3.55 gears as far as I remember.
Hoping to get to 20 mpg (definately impossible with the C6)
Old May 21, 2014 | 11:54 PM
I have a T-19 and i reguralry get 20 ... 3.55's with 35's .. all day
Trust me, that 5 speed wont really need 5th till about 65+ .... so unless your gonna run like 235/85's or 33's ...
Check my pics , its getting HG's right now, but dang good runner .. toss in a quart of ATF ( Dextron is great ) and it will help clean injectors and give ya some mpg gains..
Old Jun 11, 2014 | 04:36 PM
Joerg's Avatar
the C6 just froze and took the driveshaft with it.
Upgrade is being done right now.
Thank you very much for the tip with the ATF.
Will definately try it.
Does anybody know the driveshaft lengh (mid u-joint to mid u-joint) for a 1988 7.3 l Diesel manual transmission 4x4 regular cab?
Thanks
THW
Mar 17, 2015 08:31 PM
Jrod89
Feb 24, 2015 09:48 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
steves2500diesel
Oct 14, 2014 05:36 PM
