2nd gen 12v cummins fuel supply line..Help
Old May 9, 2014 | 10:11 AM
madeinMT's Avatar
Default 2nd gen 12v cummins fuel supply line..Help
I recently replaced my lift pump and the fuel line from pump to filter is bent all to sh*t. So I cut the line and spliced it with rubber fuel line but the fitting on pump is leaking and I cant get it to seal any ideas
Old May 9, 2014 | 03:11 PM
4x4manonbroke's Avatar
Did u flange the metal line so the rubber line fits tight ??
Also the fittings in the LP, they are British national threaded ... Nothing but that will work .. So if you have put a brass fitting that was not originally from the lift pump... Its gonna leak like crazy..
if you have the fitting, use a tubing flanger make a slight flange and smooth out the edges and put on a new line and use 2 small hose clamps, not super tight, leave some room for tightening if it leaks from there ...
keep us posted ...
Old May 12, 2014 | 09:43 AM
madeinMT's Avatar
THe problem is not on the rubber line that is not leaking "at least not yet" the leak is from the fitting at the pump. Where the male hose fitting screws into the diaphragm fitting on the pump. Seal around the threads is good. leak is coming from around outside of pipe and hole in male fitting
Old May 12, 2014 | 02:48 PM
Because of the British threads , did u use any pipe tape ? make sure you haven crossed the threads , and or cracked the housing around the threads..
Antwhite19
Mar 26, 2020 04:58 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
Omingnome
Oct 20, 2014 12:25 PM
