7.3l oil reservoir leak
Old May 5, 2014 | 10:10 PM
willieandsamsdad's Avatar
Default 7.3l oil reservoir leak
So here goes! Just did a dye test to find a leak and come to find out I have oil coming out the oil reservoir (part 6658) hrough the stud hole for 1820602-c1. It is the hole, not the stud. I switched studs and it still comes out the same hole.. The stud is one of the two mounting studs for the engine guard. Its in the back, on the drivers side. Any thoughts on how to handle this? Can I add some sealant into the hole, to stop the bleeding? Or do I need to replace the whole reservoir ($150-200)? Or could it be something deeper? I wonder if its cracked maybe. I just disassembled the fuel bowl and oil pump and they looked good, didn't see a problem with the reservoir top part, but who knows? Shoulda done the dye test first I guess.
Old May 5, 2014 | 10:33 PM
Ah, and of course the vitals. 7.3l 2002 F350. About 125k. Nice truck, but it had a tough winter and I've been chasing gremlins lately.
Old May 5, 2014 | 11:13 PM
joebob3093's Avatar
Moderator
Have you tried a new gasket?
Old May 6, 2014 | 06:36 AM
Yes, brand new gasket between the removeable top part of the reservoir and the unremoveable bottom part (gear housing) was installed over the weekend. The leak is from up top, where the stud nut seats above the hole, not along the gasket line.
Old May 6, 2014 | 09:54 AM
joebob3093's Avatar
Moderator
Huh never heard of that happening before. My guess is that you need a new reservoir. You can find a used one for pretty cheap, you don't need to buy a brand new one.
Old May 6, 2014 | 10:03 AM
The reservoir appears to be a discontinued interrnational part (#1831022C97). International refers me to Ford. Ford tells me like 20 different things and prices - all of which put me a week out.
Old May 6, 2014 | 10:55 AM
joebob3093's Avatar
Moderator
Try powerstroke army. There is a ton of guys on there and always selling stuff. I bet you can find one cheap
makuloco2000
Dec 20, 2015 11:19 PM
cummins Pride
Sep 28, 2015 12:11 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
