Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
Radio wont work
Old May 4, 2014 | 11:42 PM
Cummins75's Avatar
Default Radio wont work
So when it comes to audio I am clueless. But heres the problem I bought the truck used, has a decent system in it. But the radio will not work. I can go to fm and am stations and its nothing but static noise EXCEPT for like 2 stations on FM. They come in once in a while. can anybody help me out here? thanks!!
Old May 5, 2014 | 06:53 AM
RAW's Avatar
RAW
The antenna may have come disconnected from the radio. Either at the back of the radio, or the base of the antenna on the fender. Have a look at the antenna and antenna cable, you may find your problem.
Old May 9, 2014 | 07:40 PM
Cummins75's Avatar
Thanks for replying. I just put a new antena and cable on. It did nothing. it must be disconnected from the back of the radio? I have no idea what the end of the tip looks like so i dont even know what to look for and also where does it plug into?
Old May 9, 2014 | 09:28 PM
RAW's Avatar
RAW
Plugs into the back of the radio.
The male end (right side) goes into the radio.
Old May 9, 2014 | 10:22 PM
Cummins75's Avatar
ok thanks alot. I tryed searching for it on google but couldnt find much. Thanks for your help.
Old May 19, 2014 | 03:34 PM
Deezel Stink3r's Avatar
Make sure - if you have a new antenna, that you remove the paint from the innerr side of your fender where the antenna base sits very well. The antenna needs to see a good ground. Don't worry about rust- because you will put a good amount of NGLI grease No.2 onto it-right?
This will increase the sensivity of your antenna significantly. There will be plenty of radio stations.
Just make sure you have a good old 3feet antenna straight up to the air. Not one of these fancy tiny thingies. Remember, in car applications the antenna catches the reflection of the antenna waves from the body.
So the smaller the antenna the worse the reception.
Do not try to use one of these antenna amps- the amp is only amplifying what it gets. If it is noise- the noise will be amplified. Not good. The antenna itselve is the key for good reception!
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
cjgregory
Mar 31, 2015 01:45 PM
bonestock
Feb 1, 2015 08:41 PM
Oct 18, 2014 10:10 AM
