99 7.3 SHOP COST
Old Apr 18, 2014 | 05:04 PM
Lox4rocks's Avatar
Default 99 7.3 SHOP COST
hey guys I have been on the forum for a while but just joined. I own a 99 7.3 250 not alot done to it exhaust tuner ford hd rebuild on the trans the standard stuff. My question is,, I brought my rig to truck works in banning ca about a month ago for some swamp stage 2 double shot injectors they quoted me wayyyyyy less than my invoice and added a bunch of stuff I didnt ask for.. do you all think this invoice looks fair???? Being semi new to the diesel world I just wanted some of opinions? Thahk you all in advance.
1. Inspect engine running rough, driveability concern. Perform computer diagnostics. Codes stored
P0472-Exaust back pressure ckt. out of range, P1211-ICP higher/lower than desired while running,
P1783-Transmission over temperature condition, P0284-Cylinder #8 contribution/balance fault,
P0605-PCM memory failure
Test drive shows Boost levels low, ICP pressure @ 2000psi max. #6 injector is not functioning.
1 98.00 98.00
2. Remove valve covers and monitor mechanical operation of injectors. Perform compression test.
Compression test o.k. Replace injectors with SWAMPS stageII split shot injectors. Service high
pressure oil system and Install oil additive. Replace fuel filter and install Diesel Power fuel
additive. Install new IPR valve. Run engine and monitor high pressure oil system. Update engine
diagnostic readings.
11hrs at 98.00 1,078.00
StageII Split Shot Injectors (5yr 200,000 warranty) 8 at 205.00 1,640.00T
IPR valve 1at 264.76
Oil filter 1at 19.78
Fuel filter 1at 44.00
15/40 Diesel Oil 15at 4.99 74.85T
Lucas 1at 15.00 15.00T
Diesel Power Plus 1at 15.95 15.95T
Shipping/Freight/Delivery fee 225.00 225.00
Shipping/Freight/Delivery fee (adjustment) -112.50 -112.50
Waste Fee 6.75 6.75
Browe347
Dec 11, 2016 02:59 PM
Aug 4, 2015 09:00 PM
DieselNewbee
Apr 22, 2015 06:00 PM
g.logistics
9
Nov 22, 2014 08:54 AM
Browe347
Sep 30, 2014 11:35 PM
