6.0 Hot No Start, noone knows why
Old Apr 15, 2014 | 08:57 AM
ChiefTD's Avatar
Default 6.0 Hot No Start, noone knows why
Year of truck: 2005 F-350 335012 miles
Motor: 6.0
Cab/bed configuration: Crew Cab Long Box, lariet
Mods: EGR Delete
Anything you've done recently: Problem started two weeks ago, all changes are since then: HPOP IPR IPC Crank Sensor, batteries, starter, fuel filers, glow plugs, injectors, oil change, mass air flow/air charge, FICM updates
How is the truck primarily used: 80 mile a day commute as well as work truck on weekends
When did the issue start, and if it's intermittent or all the time: Approx 2 weeks, replaced all above, ran ok three days, back at same problem.
Anything else that might pertain to the issues at hand: have a lot of experience as a mechanic, trucks been to three other mechanics, no one can figure it out.
Any codes, and what are you reading codes with: no codes exist
Old Apr 15, 2014 | 11:07 AM
bobfbigman's Avatar
Have you also replaced the Stand Pipes and Dummy Plugs? these are also very common causes of High Pressure Oil leaks and will also cause a hot no start condition.
Old Apr 15, 2014 | 11:35 AM
ChiefTD's Avatar
Yes, they have been
Cavnar
Sep 9, 2015 07:18 PM
Accubuck
May 7, 2015 04:46 PM
cjgregory
Mar 31, 2015 01:45 PM
dandbmcc
Mar 14, 2015 11:05 PM
thumperf350
Jan 8, 2015 12:55 AM
