what did i do wrong?
Old Apr 13, 2014 | 08:04 PM
Vmason's Avatar
Default what did i do wrong?
I changed my power steering pump today and well its worse now then before. I even switched the hoses around to see if it would make it different and nothen. i was turning the steering wheel end to end while someone else was turning so there should not be any air in it. also i know the brakes and p/s are connected and i also have no brakes if that helps
Old Apr 14, 2014 | 07:32 PM
six speed's Avatar
it still has air in it. keep it full of fluid and drive it for a few days. thats what i had to do to mine.
Old Apr 15, 2014 | 07:17 AM
coors_man_2005's Avatar
Is it holding fluid. When I did my swap I wasn't paying attention. Hooked up the power steering. But the return hose I hooked up to the vacuum port hahaha. Dumb I know cummins rookie mistake. Just another thought since you don't have brakes either
Old Apr 15, 2014 | 06:23 PM
Bigg Redd's Avatar
X's 2 on air in the system. It will likely foam up a bit until the air slowly bleeds out. youll have to work the brakes and turn the steering at the same time. The air will work its way out. Its a pain in the ***.........
jjbced
Jul 19, 2015 10:03 AM
gumborancher
Apr 24, 2015 01:25 PM
Bob V
Apr 6, 2015 11:02 PM
nelly559
Feb 2, 2015 08:19 AM
cutthroatxxx
Nov 16, 2014 09:11 PM
